Engine ticking on 400ex
Old Oct 31, 1999 | 10:07 PM
Mr_00_400ex's Avatar
I have noticed that the engine on my 400ex seems to make a slight ticking noise, more so when it is warmed up. I don't have a ton of experience with four strokes so I wondered if anybodies 400ex does this to a certain degree. Thanks
Old Nov 1, 1999 | 01:52 AM
MadMark's Avatar
Have u adjusted the valves? You should adjust the valves regularly. How many hours do u have on it approximately?
Old Nov 1, 1999 | 05:01 AM
JRM's Avatar
JRM
As With any RFVC honda engine, they make a little more valve train noise than a standard 4 stroke does due to their dual "sub" rocker arm system. Excessive noice is not normal though..They will have a slight tick to them at idle. Make sure they are adj right and that the adj screw doesnt back off when you tighen the nut
Old Nov 1, 1999 | 11:04 AM
rennym's Avatar
I agree, try a valve adjustment. If the bike is new you should have one not too long after it has been broken in.
RM
99 400EX 95 Scrambler 400 85 LT250R
Big bousse
Sep 26, 2015 10:42 AM
metal249
Jul 28, 2015 09:35 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
MNatv89
Jul 7, 2015 11:36 AM
