Anybody ever fall off the ramp while loading on truck?
Old Jan 21, 2002 | 12:07 PM
shotguncreek's Avatar
I had my metal tri-folds slip off the tailgate once while loading on a concrete and since then I use the safety chains (fastened to the receiver hitch) every time I load or unload. I can see how accidents happened and one has to be real careful when stepping out of the pickup box. Am glad you didn't get hurt.
Old Jan 21, 2002 | 05:06 PM
300exazzkikr's Avatar
All i use is two boards. Lay them against the tailgate makeing sure they aren't too wobbly, back the quad up and go like hell! Don't even look back. The faster i get up the less of a chance something is going to break. I only do that if I'm by myself the rest of the time if there are two of us we just lift it up. (300ex very light).
Old Jan 21, 2002 | 08:38 PM
rangershawn's Avatar
Guys,
The type of ramp im using is quad boss aluminum bi-fold 1500lb capacity.I really did not do my home work on the ramps.I just bought what the dealer had at the time.The ramp came with these safty straps i hook on to my cargo tie down hooks in the bed of my sb silverado.I think i may look into buying some alluminum flat stock high enough so the tires ride on the inside to keep from slidding side to side.I will use screws to mount them.
I feel pretty safe with the straps.Keeps the ramp from kicking out.
My original post is meant as a warning.Be carefull when driving up the ramps if the tires are wet.
I am a first time atver, im learning the hard way.I have to try diffrent things to do this.Nobody is holding my hand.I am sure i will get good at this soon.
Any other ??'s please ask.
Later,shawn
Old Jan 21, 2002 | 11:41 PM
QuadZmoto's Avatar
Ranger, I can sympathize with you. I did the same thing. Just came back from a 5hr good ride, everything went great, no flats no close calls, until I loaded my Wolverine into the truck. I used 6 ft 2x6 with metal ends. I got 3/4 way up when the tires started to spin, what I should have done was backed it back down and asked for help, but NOOO, what did I do? you guessed it, hit the gas hard, the back boards spit out and over the quad and I went. It did fell like slow motion. Thank god nothing happened to the quad. Luckly I had my helmet on because my head smacked the cement. Whats weird is I always take my helmet off as soon as we get back. I bruised my elbow real bad. I am going to by those metal ramps.
Old Jan 21, 2002 | 11:55 PM
  #15
sandrews46's Avatar
About 6 months ago a man from my hometown was killed while unloading his four wheeler after a day of riding. I was told it fell off of the ramps somehow and landed on him.
Old Jan 22, 2002 | 02:26 AM
  #16
Kraig9940's Avatar
I always use my winch to load my Recon. (this is after I fell off one day in the driveway) :-) I installed a heavy duty cargo hook in the front floor of the truck bed. It works really well, As I load it, I can either sit on it or stand off to the side. The cargo hook looks nice and was easy to install. I wouldn't recommend using the standard (factory) hooks, they aren't designed for the load that is put on them by the winch. I have some photos if you would like.
Dewhound
Apr 20, 2017 02:25 PM
shimanok2
Jan 29, 2016 07:37 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Riding Gear
Sep 15, 2015 02:59 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
