3rd headlight on rubicon??
Old Jan 22, 2002 | 08:04 PM
boneylong's Avatar
a friend of mine just bought a new rubi and he is wanting to know the easiest way to put a switch on the 3rd headlight to turn it on off instead of all of them coming on at once.
Old Jan 23, 2002 | 04:54 AM
trailboss450's Avatar
25 Year Member
Its real simple to do! I frequently carry big loads on the front rack so I need to shut off the light to stop the glare in my eyes. When you pull out the 2 bolts on the side of the headlight pod the headlight housing will come out. The wires are pretty short so you might want to lengthen them a little to make things easier. I drilled a small hole in the bottom of the pod (in a protected spot) for the toggle switch. Locate the hot wire going to the headlight, (there are only 2 wires going there and 1 is the ground) Cut that wire and run it to each side of the toggle switch.
Also I found that the upper light actually has 2 filiments, (a high and a low beam) but for some reason Honda chose not to use the low beam so it is not wired for use. If a guy wanted to he could wire that up too so the high and low would both work.
Whitelx1
Oct 2, 2015 10:55 PM
PrairieDog126
Sep 16, 2015 01:33 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
