carb problems...
Old Jan 23, 2002 | 03:03 PM
350rcherdude's Avatar
how do you get it to idle back down. the idle screw doesnt do any thing cause it idles so high, could it be that the E clip on the needle is on the wrong setting ?? thanks in advance.
Old Jan 23, 2002 | 09:02 PM
seven's Avatar
If your idle screw will not affect it you need to adjust your air mixture screw.If this does not fix it,then your pilot jet is to lean
Old Jan 23, 2002 | 09:51 PM
i am not trynig to sound like a complete moron and not know any thing but i usally dont messaround with the carb if it runs i leave well enough alone. but which screws are which.i dont want to turn or tighten the wrong ones.
Old Jan 24, 2002 | 12:38 PM
seven's Avatar
If your carb is tuned right your air screw should be 1 3/4 turns out.It will be a small flat head crew that is almost flush or barely sticking out on the side towards the bottom of the carb
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
