Anyone have an HOUR METER???????
I have a new hour meter I want to install so I can keep track of the time the new top end has under it. The meter has two copper/gold colored connectors in the back.
Where on a 400 can I splice in to make the meter work only when the engine is running,and not when the key is just on. How should I wire it, is my question.
-Matt
-Matt
Is there a place you can install an oil presssure switch?
We use a swtich at work that is normally open, pressure closes the circuit so the meters will run and these switches are 3psi to close.
I not fammiliar with the 400 enough to be able to tell you where to plumb it in.
jrooker6
Apr 23, 2016 07:36 PM
IMLN
Sep 28, 2015 03:32 PM
kbazzy
Sep 26, 2015 11:26 AM
