What is the stock power of a 250r?
Old Feb 15, 2002 | 10:12 PM
Toaster's Avatar
That's it... What is the stock power of a 250r? And maybe some specs like his stock speed, stock front sproket teeth, stock width, stock length. Thanks...
Old Feb 15, 2002 | 10:53 PM
350rcherdude's Avatar
hey,i got a good site to find out every thing you want to know about 3 wheelers it has liknks to other 3 wheeler sites and stuff it is really good. go to www.3wheeer.org
it should have that stuff but not top speed. i dont think when ever you find out what it is let me know. i am curious.
_____________________________--
1987 atc 200x -bone stock.
1986 atc 350x-stock becides kn filter,bigger jets,supertrap exhaust.
Been there,Climbed that.
Old Feb 15, 2002 | 11:30 PM
Toaster's Avatar
Thanks, but i am talking about the trx250r...
Old Feb 16, 2002 | 12:04 AM
PaRoostR's Avatar
Front sprocket: 13 Tooth
Rear sprocket: 86-87 39 Tooth, 88-89 38 Tooth
Honda TRX250R FourTrax
Displacement: 246cc (15 CID)
Bore & Stroke: 66mm & 72mm
Compression: 1986 7.5:1; 1987-89 7.7:1
Carburetor: Keihin 34mm PJ oval slide
Lubrication: premixed oil
Starter: kick
Ignition: CDI
Transmission: 6-speed, manual clutch,
Final Drive: #520 chain, O-ring sealed
Wheelbase: 51.0"
Overall Length: 71.9"
Overall Width: 44.5" @ rear, 42" @ front
Overall Height: 42.1"
Footpeg Height: 13.25"
Seat Height: 29.75"
Ground Clearance: 4.3"
Fuel Tank Capacity: 2.64 gal. (including a 0.53 gal. Reserve)
Front Wheels: aluminum 21x7-10, bolt pattern 4/144mm
Rear Wheels: aluminum 20x10-9, bolt pattern 4/110mm
Front brakes: two hydraulic disk, dual piston caliper
Rear brakes: one hydraulic disk, dual piston caliper
Front Suspension Travel: 7.9" double A-arm pre-load adjustable
Rear Suspension Travel: 9.1" Pro-Link progressive rate linkage, remote reservoir damper with 21-way rebound and 12-way compression and pre-load adjustments
Caster angle: 6°
Dry Weight: 328 lb.
Cole Hadden
Jun 15, 2025 09:05 AM
slowgsxr97
Mar 18, 2022 03:40 AM
Dustinyoungs
Jul 24, 2015 07:18 AM
CRamshaw777
Jul 18, 2015 05:46 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
