400ex jumping
Old Feb 19, 2002 | 11:13 PM
CornDog's Avatar
<< i do the same thing nose dive! sometimes it lands sideways. that really sucks. i think i might go back to a dirt bike. something about jumping a quad just aint right. to heavy. i weigh 215 plus the quad weight. thats almost 600 pounds flying through the air. a bike is much lighter an more controlable. >>
i land sideways all the time! jumpin quads is scarey.
Old Feb 19, 2002 | 11:23 PM
briansgi's Avatar
If you are always landing sideways, you might want to check the air pressure in all 4 tires.
Old Feb 20, 2002 | 12:23 PM
grademan's Avatar
YZguy gave me this link for shock adjustments:
http://off-road.com/atv/suspension/shockadj.htm
Jumping a 400 is like 2nd nature. If you're having problems, you're definately not doing something right.
You're always going to have an occasional crazy landing, but with a 400 you shouldn't have to try too hard.
Old Feb 22, 2002 | 12:17 PM
YZGUY's Avatar
See the article Grademan mentioned. Don't even leave the garage without your suspension properly adjusted!!!
Old Feb 22, 2002 | 12:29 PM
  #15
trx250Rob's Avatar
YZguy, why is there such a difference in jump setup between 2 and 4 strokes, is it the fact that 4 stroke engine brake alot more than 2 strokers?
Old Feb 22, 2002 | 12:47 PM
  #16
TRXter's Avatar
<< i weigh 215 plus the quad weight. thats almost 600 pounds flying through the air. >>
redryder01, I'm tipping the scales at 220 astride my not too svelte Bombardier. The weight does make a difference. This beast is alot scaryer to jump than either my YZ250 or 400EX, but it can be done. The payoff is the look on those dirt bike pukes faces as you clear a double.
Old Feb 22, 2002 | 10:57 PM
  #17
Shift's Avatar
4 strokes have ALOT more compression braking than 2 strokes do, it may not feel like it, but they do. When you go off the jump on a 4 stroke you need to hold the throttle steady and stay centered if not a little towards the rear of the bike. On my R I just blip the throttle on takeoff and lean a little forward, but I tried it on my bro's 400 and almost died... hehe.
Old Feb 22, 2002 | 11:21 PM
  #18
Varmit's Avatar
On a 4 stroke you can make the landing a lot softer if you pin the throtle right before you hit the ground. It doesn't make much diffrence on a 2 stroke but on a 4 stroke it seems to stiffen the rear suspension and takes a lot of the load off the front. It sure makes them big doubles a lot more fun, expecily when you over jump them. Beleive me I'd much rather jump long then short anyday...
Old Feb 23, 2002 | 12:37 PM
  #19
RubiconMan500's Avatar
I have learned to lean back good while in the air, and keep on the throttle dont let off in the air, it will make landing alot better. That really helps if you nose dive to hit the throttle as your front wheels do to drop the back end sooner and you will still have speed.
Old Feb 24, 2002 | 04:38 PM
  #20
Mitteer's Avatar
Thanks everyone I will setup my suspension and keep trying.
Matt
