400ex starting in cold weather?
Old Mar 6, 2002 | 12:39 AM
Toaster's Avatar
I live in Quebec, Canada and on winter we see alot of -10 to -20 degre faraneith and yes, the 400ex will start. Do not forget to start full choke, pull 5 to 8 time on gaz and maintain it for 1 or two mininute and then after 5 minute of run, you can release your thumb of the gaz. The 400ex is a freezing atv, but can start on cold weather.
Old Mar 6, 2002 | 01:34 AM
guardog's Avatar
my buddy has a 400ex and it was a bear to start too. I live in northern PA and it's freezing up here. He put in a splitfire spark plug and has no problems since. I highly recommend the splitfire.
Old Mar 6, 2002 | 09:04 AM
Quadfather's Avatar
Maddog:
If you take the spark plug wrench in the tool pack, and grind a bit off of the outside square sides (round them out a tad) it will fit fine.
Also, changing the pilot jet to a 42, or a 45, seems to cure the cold start problem. Mine starts fine, but that seems to be the cure on another forum that is dedicated to EXs.
Old Mar 6, 2002 | 12:35 PM
Mitteer's Avatar
Yes my 400ex is a bear to start below 60 F. Choke it fully when it starts move it to half-choke and stay on the thumb throttle for a couple of minutes.
Old Mar 12, 2002 | 10:48 PM
  #15
HondaMarshal2's Avatar
Yes the 400EX is a cold blooded son of a gun. But I wouldn't trade it. I did put the splitfire plug in and it has been considerably better. I am doing some homework on the Edelbrock Qwiksilver Carb and it said the the Edelbrock virtually eliminates hard cold starts on the 400EX. The only problem is the $450 price tag. I'm going to get it.
Old Mar 13, 2002 | 08:13 PM
  #16
grademan's Avatar
When I bought mine the dealer said it would be cold blooded for the first year or so, then when it got a little older, it wouldn't have that problem. Is this true?
Old Dec 5, 2002 | 01:18 PM
  #17
StevieD's Avatar
Default 400ex starting in cold weather?
i just found out what a pain up the butt they can be to start in the winter. after a good 5 minutes of cranking, it wont even come to life at all!
geez..
Old Dec 5, 2002 | 02:21 PM
  #18
vooduuchild's Avatar
Reading all this makes me realize how blessed we Z400 owners are.
Old Dec 5, 2002 | 03:52 PM
  #19
chad400ex's Avatar
C'mon boys...a 400ex isn't that hard to start. The carb comes lean as he!! from the factory. Replace the pilot jet with a 42 ,and you'll never have to turn the choke on or have a tough time starting it again. There have been plenty of discussions on here about this. You also want to keep the battery on a trickle charger if letting it sit for more than a month. I use the Battery Tender, and never have a problem starting my quad. I ride in the mountains and the snow this time of year, and I've never been let down yet.
Old Dec 5, 2002 | 09:17 PM
  #20
StevieD's Avatar
wtf? mine will not start no matter what i try! i dont have the tool that comes with the ex to remove the plug, and i dont have the right size socket, so i cant even get the freaking plug out!!!
why the heck is the plug so hard to get to?
