250r Rear Caliper for 400ex?
Old Mar 16, 2002 | 04:50 PM
250rampage's Avatar
I'm starting to really think about swaping out the Rear Caliper from a 250r onto my 400ex. I want to go to the twin-piston setup for stronger braking and improved pad life due to almost twice the braking surface area. I'm pretty confident I can fabricate the mount (if needed), but my main concern is the rear master cylinder. Will it have enough power to push the two pistons? Is the 250r unit a stronger pump? If it is i'll switch over to that too.
Old Mar 16, 2002 | 05:09 PM
ladyhonda250r's Avatar
you won't need the rear master cylinder it will be able to handle both piston's easy it's just the caplier they changed
Reactant
Mar 30, 2022 02:08 AM
toonces
Aug 25, 2015 06:09 AM
DeFox500
Aug 14, 2015 05:59 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
Sandman2.0
Jul 21, 2015 09:03 AM
