Turbo Kit on 400EX??
Old Apr 23, 2002 | 07:42 PM
hondaquadrider's Avatar
I was reading the new dirwheels today and seen the turbo kit that they had for the 400EX and Raptor and i was wondering, what is the consequences or downfalls of one of these, can you ride on long ride trips with these without them overheating............I know we have 2 diesel trucks that have turbos on them and if you get the pyrometer up to so high they will just melt the turbo and the block?...........thanx for any info you can give me on these turbos.
Old Apr 23, 2002 | 07:50 PM
icav's Avatar
well........I dunno.........I wonder if you can put a turbo kit on a dale.......
Icav
Old Apr 23, 2002 | 08:30 PM
trapperb1's Avatar
From my understanding, yes, you can install and ride. It will instantly DOUBLE your horsepower. It will also cost you over $4000!
Is it worth it?
These turbos will act like any other. I know on diesel trucks, we had to watch the pyrometer so we wouldn't overheat them. Same here, but like the trucks that have inter-coolers, they don't get quite so hot.
Old Apr 24, 2002 | 10:27 AM
Mitteer's Avatar
The bad part of these turbos is the debris from your transmission and clutch. This kind of debris is not good for a turbo. Also I do not think there is enough oil cooling for a turbo on these machines.
Old Apr 24, 2002 | 12:02 PM
trx250Rob's Avatar
I think this kit will make a great duner/drag project but I don't think it would be reliable for everyday use due to the added stress on the crank and transmission. I think I read in the article that they where using a stock piston and crank, correct me if I'm wrong.
Old Apr 24, 2002 | 12:26 PM
HondaMarshal2's Avatar
I think that when you start messing with these "unproven" motor hop ups you run into trouble. Don't mess with Honda reliability. If you want pure speed buy a Raptor,DS650, or Cannondale.
Old Apr 24, 2002 | 05:06 PM
Mitteer's Avatar
I believe the reason for the stock piston is usually turbos work with lower compression pistons. I believe I read this on a car web site. I will try to find this.
Old Apr 28, 2002 | 06:27 PM
dacuteboy4u's Avatar
I would wait till something less exspensive and better comes out.
250ex stock.
Old Apr 28, 2002 | 06:37 PM
kciH's Avatar
You cannot run high compression with a turbo, the motor will produce way too much heat. The turbo forces more air/fuel mixture into the motor, which is kind of like increasing the compression ratio.
Old May 15, 2002 | 11:31 PM
Little400's Avatar
[img]i/expressions/face-icon-small-shocked.gif[/img] get A L O T of butt pads, 'cause if you turbo charge it, you'll be flying backwards if you don'y be E X T R E M E L Y careful.
