Smokin' 400EX??
Just got my new 00' 400EX about a month ago and it seems everytime i start her up(cold or warm outside) in the morning for the first time it smokes a little. it only lasts for about a minute and then quits. it looks like it is burning oil but it was broke in exceptionaly well and never ragged on. do any of you have this same problem?? any suggestions on what it could be. oh yeah, it even did it when i started it up at the dealership to pull it in the back of my truck but the mechanic said it was just the new packing in the muffler.
They are very cold blooded, all Honda's that I've seen so far. I have a 300EX, and the only time it doesn't need choke is on the days when I don't wanna ride because it's too hot out! It should be normal, especially if it's cold out.
MY 400EX DOES THE SAME THING IT IS NORMAL, I CALLED THE DEALER. IT ALSO TAKES A FEW MINUTES TO WARM UP.
I have a 99 400EX it also smokes some when its cold. I try to let it warm up good before i ride it so that it wont do that. Mine has been like that for almost a year now and still runs strong and is trouble free.
CB400EX
CB400EX
I have never seen my EX smoke. Moisture in the pipe would let it smoke on a cold day but you said it will do it no matter what the weather. I would make sure that the dealership has noted in your file that you were concerned about the smoking and then I would call the factory to get thier take on the story. Compression check would not hurt either. If it is blowing by the rings or past a seal then you will see it under a heavy load. Always get a second opinion.
