Difference between 42-1 and 32-1 mixture?
Old Jul 21, 2002 | 07:09 PM
DesertBum's Avatar
After son rode the ATC with the 32-1 he said it was slower in top end then the 42-1, is he right? I really didn't notice...
Ron
Old Jul 21, 2002 | 08:40 PM
tprender's Avatar
I am not an expert on this, but you son should not be able to tell the difference between the 2. From 32 to 42 is not that much of a differnce. Plus did you empty the tank and carb when you changed the mixture? If you poured the one into a not empty tank it is some mixture between the 2. A mix of 20:1 and 40:1 you will fell some difference. Which one did he say was faster? The 42:1 should be the faster, because the gas is less diluted from the oil and your octane number will be somewhat higher I think.
If you changed pre-mix oils you can fell the difference.
Old Jul 21, 2002 | 09:10 PM
DesertBum's Avatar
Changed pre-mix and ratio's. Also, I didn't empty it fully.
To: Castor Pro 32-1
Johnny Mac
Aug 15, 2019 03:13 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
fredrikrosen
Sep 28, 2015 09:58 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
