recons running lean?
Old Aug 12, 2002 | 08:47 PM
01redrecon's Avatar
I was talking to my local atv parts dealer and he said that he has heard of a few recon that have been running lean. I don't think mine is, but how can I tell?? and has anybody had this problem??
Old Aug 12, 2002 | 09:35 PM
yaright's Avatar
ours has always run really rich even when we bought from the dealer
Old Aug 12, 2002 | 09:55 PM
hot_shoe_cv's Avatar
If you bought the bike used, it's possible the former owner had changed the main jet or adjusted the needle jet for some reason. If it was owned previously, the first thing I'd do would be to pull the bowl from the carb & see what size the main jet is. You can contact the dealer's parts dept. to get the stock size. Then check the jet needle to be certain it is in the nominal position, which is the 3rd position. If all this is correct and you've made no airflow modifications, it SHOULD not be lean. But as always, the only real way to know is to ask the engine what it needs. That's done via a test ride/plug read with a brand new plug.
If you're unclear how to run a test/plug read you can email me for my tutorial on the topic.
Old Aug 12, 2002 | 11:21 PM
atc86r's Avatar
check your plug color that should tell you. is your recon totally stock?
Old Aug 13, 2002 | 08:15 PM
01redrecon's Avatar
Well my bike is kinda used?? It was my brothers and i drove it most of the time and then i bought it. As far as I know he hasn't done anything to it and yes it is all stock ecept for the tires. Right now it is in getting a tune up and service, so I don't know the color of the spark plug. But I guess I should have asked is if the bike would run any different, if it is lean(like sputtering or low power)
Old Aug 13, 2002 | 08:30 PM
when operating on the main jet, that is, 3/4 to full throttle, a lean air fuel mix will cause the engine to cut out intermittently and the engine will run hot.
TextAs I said in the previous reply you need to do a proper test and plug read in order to know what's going on in the engine and you need to do it now![img]i/expressions/face-icon-small-smile.gif[/img] before you have engine damage. You can't tell anything by reading your old plug. Use a new one and do a proper test, not just a ride around the neighborhood.[img]i/expressions/face-icon-small-frown.gif[/img]
honda recon 250
Jul 3, 2015 01:50 PM
honda recon 250
Jun 25, 2015 09:40 PM
honda recon 250
Jun 24, 2015 04:52 PM
Jun 24, 2015 01:40 AM
Jun 10, 2015 12:45 AM
