400EX XR400
Old Mar 29, 2000 | 11:36 PM
Booboo's Avatar
The 400EX and the XR400
Is it the same motor? If not, how similar is it?
I would assume thay are very similar. So could you maby take the kick start off a XR and put it on a EX??
Old Mar 30, 2000 | 10:32 AM
400exalltheway's Avatar
I was wandering the smae thing. I think the engines are almost excacly the same except the xr400 has a kickstart. I would much rather have a kick start and lose 20-30lbs
Old Mar 30, 2000 | 11:15 AM
86atc250r's Avatar
They modified some stuff.
The gears are thicker, the cam is different, they molded new cases (which prevents the easy addition of a kick starter), and I believe they lowered the compression.
Old Mar 31, 2000 | 06:02 PM
Matrix's Avatar
The lower compression is a result of a thicker head gasket. You can install a factory xr400 gasket to get it back.
Matrix
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
