mod blaster vs stock 400exer!!
#42
Why not heres a quote from 400ex pipe shootout
so a piped ex is about 28hp
Heres the dyno chart for the 240kit
CT Racing Blaster Link
its 41hp so obviously this is not at the rear wheels so you lookin at probably 35hp at the rear wheels and even if you think thats high its got to have atleast 30hp
the blaster is 50lb lighter
so how could it not be possible
not that there's something wrong with the 400ex and a 240kit on a blaster would not be near as reliable as a 400ex cause it would be more of a high strung motor meaning a shorter life. and the 400ex is obviously a better mxr better brakes, suspension, handling
but to say that a bllaster could not beat a 400ex in a drag is not true it is possible with lots of $$$
Some provide a significant increase in peak horsepower over stock. Others produce nearly the same peak power as stock but provide significantly more at lower rpm. Both CT and White Brothers E top the charts with 27.9 horsepower at the rear wheels verses 26.9 on the stocker.
#46
sorry to break up the party but any stock bore 400 on here i don't care if you r piped or not my blaster has never been beat by a 400 i have even beat 416 and 440exs i have 14/37 gearing (stock is 13/40) i beat stock 400s so bad i stop when i hit 5th gear you guys need to realize your 400s aren't as bad as you think
by the way i am not a scrawny punk either i am 6'1 165lbs and a amauture boxer so don't say only little kids ride blasters
#48
well said bad blaster
see thats what i was trying to say with some money a blaster can be made to go faster then a 400ex
it is possible guys
nothing against the ex tho its a good quad
rather have a z tho
l8r
it is possible guys
rather have a z tho
l8r
#50
um what mods you have on your mojave it shouldn't be smokin a blaster i'm not exactly sure whats faster but a piped blaster should not get smoked by a 250cc four stroke that is heavier jmo
