AMSOIL in the rinny????????
Old Jan 2, 2003 | 08:20 AM
ostie's Avatar
Default AMSOIL in the rinny????????
This is from the Mobil web 1web page addressing the myths of synthetic oils.
"You should break in your engine with conventional oil, then switch to Mobil 1. "
You can start using Mobil 1 with SuperSyn™ in new vehicles at any time, even in brand-new vehicles. In fact, Mobil 1 with SuperSyn™ is original equipment (it is installed at the factory) in:
Chevrolet Corvette
All Porsche vehicles
Mercedes-Benz AMG vehicles
Dodge Viper
Ford Mustang Cobra R
All Aston Martin cars
One of the myths that persists about Mobil 1 is that new engines require a break-in period with conventional oil. Current engine manufacturing technology does not require this break-in period. As indicated by the decisions of the engineers who design these high-performance cars, Mobil 1 with SuperSyn™ can be used in an engine from the day you drive the car off the showroom floor.
"Mobil 1 will leak out of the seals of older cars"
Mobil 1 does not cause leaks. In fact, new Mobil 1 with SuperSyn™ was tested in dozens of industry standard and OEM tests to prove its seal performance. It is fully compatible with the elastomeric materials from which all automotive seals and gaskets are made.
ExxonMobil engineers are wary of conventional oils that tout their use of additional seal-swelling agents. With extended use, these agents can over-soften engine seals, resulting in leaks. More to the point, an oil additive will not rejuvenate worn or damaged seals. The damaged seal may have been caused by a worn rotating metal component in the engine.
If an older engine is in good condition and does not have oil leaks, Mobil 1 with SuperSyn™ provides the same advantages as when used in a new engine. ExxonMobil recommends taking measures to repair the leaks, then using Mobil 1 with SuperSyn™. ExxonMobil also always recommends following the automobile manufacturer's manual for the proper oil to use.
Sep 15, 2015 02:42 AM
hondaguy2
Sport Quads
Mar 1, 2004 06:18 PM
Duramax
Nov 23, 2003 07:17 PM
RinCon4LiFe
Mar 20, 2003 12:56 AM
