FMF pipe not fitting on 87' 250R
Old Apr 5, 2000 | 01:12 AM
oregonrider's Avatar
I've got a 87' 250R and I'm trying to put a FMF gold series pipe on. When I couple the pipe to the header all the way the first bend of the pipe rests against the frame. Also, the bracket is about an inch off. Does the pipe and header coupling have to be fully engaged, or can I slip it out a little? The directions say to use the stock mount bolted to the back of the front engine mount. But I can't figure out which way. The one thing that throws me off, is the stamped logo (fmf) faces tword the ground when assembled. The label attached to the pipe said HONDA TRX 250R 87-89 Rev
Has anyone come across this configration?
Also any good starts on Jetting ?
I've got; K&N air filter, boysen reeds on stock cage, fmf rev pipe, turbine core II silencer, LRD boost port pro-X coated piston and standard head gasket.
Before all those I was running the stock 152 main, 148 pilot and #3 groove. ---alt. 0-400 ft
Old Apr 5, 2000 | 09:40 PM
Spinks250r's Avatar
I have an '87 with the FMF Fatty with a Power Core 2 silencer. It bolted right up. I also have a FMF Ram Valve, K&N with outer wear and no lid on my air box. My jetting is stock with a 160 main. Good luck
Old Apr 6, 2000 | 11:26 AM
tprender's Avatar
If I remember corectly FMF make 2 pipe. One for the 86 and 87 and a different one for the 88 and 89. I have made them fit on both quads. The mounting bracket at the bottom of the frame does not line up. you need to make a spacer out of 3/4" flat metal and some kind of spacer to mount the pipe.Get the spacer that mounts inside exhaust flange to give you some more low end if you want some. This can be gotten at a muffler shop.
many 250r"s
87 250x
99 400ex
Old Apr 7, 2000 | 06:07 PM
philzie's Avatar
I had the same trouble putting FMF on my '85 ATC 250R. I had to modify the pipe a little to make it fit.
I put FMF on my wifes Blaster and it bolted up great, but the pipe was touching the bottom of the gas tank. It melted the tank slightly, I didn't notice it until I pulled the gas tank off at a later date.
Old Apr 14, 2000 | 12:01 AM
b(250rman)'s Avatar
I ordered a FMF faty for my 86 trx250r after being 2 weeks late it finaly came except it was for the 87-89 trx 250r I hate golden west cycle. remeber ride smart ride hard and ride red!!!!!!!!!
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
tysonbully
Sep 28, 2015 02:30 AM
ltzbrad
Sep 25, 2015 05:52 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
