diffarential on forman s
Old Dec 17, 2002 | 09:31 PM
tommyboy84's Avatar
Default diffarential on forman s
Hey guys can any one tell me if the diffarential (i can't spell) on a forman is week or strong?
I mean does only one front wheen do all the work or does the other oone help any at all? I really wish honda would put a locker on the formans.
Old Dec 18, 2002 | 12:50 AM
tommyboy84's Avatar
Come on guys!
Old Dec 18, 2002 | 01:56 AM
swampdonkeykiller's Avatar
Yeah only one wheel at a time really does any work on the front end. A detroit gearless locker from highlifter.com sounds like the best bet though. Supposedly it puts power to both front wheels all the time but allows one to turn faster than the other when turning. Check out their website.
Old Dec 18, 2002 | 09:54 AM
Farmr123's Avatar
It is pretty strong in terms of not breaking.
However, it doesn't lock both front wheels together. What it does, is holds them with a certain amount of force, that in some instances can be overcome. The more torque run through it, the tighter it is supposed to hold, and in some cases, if one front wheel is spinning without the other, you can pull on the front brake, and both front wheels will turn together.
Old Dec 18, 2002 | 09:38 PM
tommyboy84's Avatar
If I put a locker on a foreman with trax-lock would I have to put on another awitch or would the locker kick in with the 4x4 switch thats already on it?
Old Dec 18, 2002 | 09:41 PM
tommyboy84's Avatar
Also when your in 4wd will it have ingen breaking at all 4 wheels? and when in 4x4 if I hit one break will it couse breaking on all 4 wheels?
Old Dec 19, 2002 | 03:44 AM
nick01's Avatar
The locker should work fine with the trax-lok. You will have four wheel engine braking when you let off the gas, when in 4-wheel drive, and when you hit the brake all four will get stopping power. Sometimes you will have a fourwheel drive and sometimes three without the locker, each time it's like the luck of the draw.
Old Dec 19, 2002 | 09:56 AM
450HondaForemanS's Avatar
Has anyone ever been in a real situation where they were actually stuck and would have gotten out with a locker. I doubt it.
Old Dec 19, 2002 | 01:20 PM
action450s's Avatar
Yes, if your into seroius mudding you'll notice the difference. A freind of mine got crossed up in a ditch on a Kawi 650. I drove it out for him. She was spinning wildly until I pulled the lever and she came right out.
Honda's limited slip fron end is OK when new, but doesnt compare to a Locker from HL.
In 4wd any braking causes braking on all 4 wheels, in 2wd braking occours on Front or back.
Old Dec 19, 2002 | 07:55 PM
tommyboy84's Avatar
hey guys thanx for the info but i have another queastion. What it the top speed your getting out og your 450foremans?
