OIL TEMP. LIGHT AND FAN ON
Old Dec 27, 2002 | 08:44 PM
lenray's Avatar
Default OIL TEMP. LIGHT AND FAN ON
87 Honda 4 trax Foreman when I start the Honda the oil temp. light and the fan are running-the fan is running while I am cranking the engine on start up.
It does this here in Michigan in the cold weather say at 20F.
When is the fan supposed to be working when it is working correctly and what should I BE looking for as to this trouble.
Thanks for any help.
len
Old Dec 28, 2002 | 12:34 PM
Harw's Avatar
On the right side of the motor behind the foot brake is a tin plate. Remove it there are two switches unplug them while the bike is running if the fan shuts off then replace the switch. If it does not look for a bare wire.
Old Dec 28, 2002 | 02:18 PM
lenray's Avatar
Thank you WEST VITGINIA
I love touring your state I will give that a try wasn';t sure where those wires were located .
I really appreciate your sharing.
len
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
