Rejetting question
I'm not familiar with the Recon, but as is the case with most Honda quads or bikes the carb is a Keihin and much easier to get at the main jet via the access bolt at the bottom of the bowl. What makes you think you need to rejet or are you just curious about the process? If you plan to change the main jet, a jet wrench is a handy tool to have for a Keihin. Only a couple of dollars.
Well I want to install a better air filter and modify the airbox, I was told that since the Recons come lean form the factory to begin with I would have to rejet if I do any modifications.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
