250r HELP - will not run right.
Old Jan 13, 2003 | 10:16 PM
Thrill20's Avatar
Default 250r HELP - will not run right.
Thank you all. You've been very helpful. I'll pull the carb back off again and replace the reeds since they seem to be the least expensive option, and it can't hurt. I'll check the jetting and clean it again and see what happens.
As far as mods, it's piped with a uni air filter. I'm still running with the air box cover on though. Will the 38mm air striker be to much, or can I jet it down for a mostly stock motor? I wouldn't mind having a bigger carb, because we all know stock never stays that way. Well, it sounds like worst case I'll be dropping a couple of bills on a new carb. Not bad for a $500 quad though[img]i/expressions/face-icon-small-happy.gif[/img] Yeah, what a steal eh?
Anybody else from Michigan know some good areas to ride? I usually ride trails around Atlanta or Baldwin. I haven't been to Silver lake on the quad yet, but will hopefully this summer.
Thanks again to every one. Ride on.
Thrill
Old Jan 13, 2003 | 11:53 PM
trx250Rob's Avatar
Good luck
Old Jan 14, 2003 | 12:58 AM
Harw's Avatar
Run a ground wire from the stator cover along your other wires up to the frame ground on the left side by the rad. bolt the new ground wire in with the harness ground. If you have a bad ground that will fix it. A poor ground will cause all kinds of weird problems.
Old Jan 14, 2003 | 01:22 AM
garyc660R's Avatar
I have had good luck with BRAKE CLEANER when cleaning carbs.....good luck and keep us posted....where was the case busted?
Old Jan 14, 2003 | 02:27 PM
  #15
Thrill20's Avatar
The guy I bought it from threw the chain. The case was busted underneath the shifting shaft. Luckily I work with some really good welders. I plan on replacing both case halves eventually. At a couple of bills a piece though, I'll see how the repair holds up.
Thanks again. I'll keep ya posted.
Old Jan 14, 2003 | 04:38 PM
  #16
arsonist678's Avatar
i also have a 38 A/S carb
it works good no low end loss
easy to tune acually i got lucky and got it right the first time
you should use around a 180 main
i had problems with gas leaking runing like crap and not starting good so i just bought the new carb
Old Jan 14, 2003 | 05:29 PM
  #17
trx250Rob's Avatar
Same here, I just bolted it on and that was it. It was the best spent $200 ever.
Old Jan 14, 2003 | 08:28 PM
  #18
theHulkamaniac's Avatar
My carb gave me problems forever, cleaned rejetted, new jets old jets. Finaly trashed it, new carb also did reeds. Perfect since!
Good luck!
franklyme
Oct 21, 2016 07:18 PM
r1pilot83
Sep 27, 2015 07:38 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
