too much wheel spin
Old Feb 1, 2003 | 09:39 PM
o3thirdeyeo3's Avatar
Default too much wheel spin
i have an 86 250r and i have way too much wheel spin. i have 18 inch holeshot mx. i have a 13 tooth front sproket, and I think I have a 45 tooth back sproket. I can get into about 3rd gear pinned from almost a dead stop. i dont know what my gearing is so im thinking about changing it. any ideas?? thanks alot
Old Feb 1, 2003 | 10:24 PM
RAZOR13's Avatar
dont mess with the back at first, start with the front go up 1 tooth at a time
going up one tooth in the front is like coming down 3 teeth in the back or vise-a-versa
the fronts easer to change,,,, then later buy more sprockets and start having funnnnnn tru different combos
Old Feb 1, 2003 | 10:34 PM
powerslider's Avatar
Stock gearing is 13:39 with 20" tires, your running 13:45 with 18" tires??? You should be able to launch in at least 3rd. 14:38 should get you where you need to be depending on the size of the track if indeed your racing.
Old Feb 2, 2003 | 12:53 PM
adamsmith's Avatar
Most people on modded R's run somewhere around 13/39. I run 15/36 on my 4 strokes with 18" tires.
Old Feb 2, 2003 | 01:50 PM
Buzz440's Avatar
Your gearing is way to low. you could probably pull a jumbo jet with your R right now. Take the rear to about 38T or 36T then change the front plus 1 tooth at a time till you like what you get.
Old Feb 2, 2003 | 03:48 PM
Yomama's Avatar
Yes gear that puppy up. I run 13/44 for running on 4X4 trails with my Ute buddies. On my 250R ATC I run 14/38 in the dunes & still pull easy 2nd gear holeshots.
Old Feb 2, 2003 | 05:44 PM
RichR's Avatar
Message to HondaRincon4Life,
Your an embarrasement to Honda riders everywhere!
You obviously have no clue what a 250R is, or what it feels like
to hang on to the bars!!!
Bring your Rincon over to the west side of the state and i will
show you what my rear grab bar looks like from far far far behind !!!
Sorry for the flame all......some people just are clueless
Old Feb 2, 2003 | 07:41 PM
lonestarbanshee's Avatar
I run 13/39
Old Feb 2, 2003 | 08:06 PM
Yea, i need to change my gearing because i am so slow on top end a 300ex could would be a close drag [img]i/expressions/face-icon-small-blush.gif[/img] i will try what some of you guys said... and would tire pressure make a diff.? if so i am running 5lbs
Old Feb 3, 2003 | 12:42 AM
leandean's Avatar
Buzz 440
i have a 416ex, im using stock gearing now, im thinking of trying 16/36 like your setup. You think this setup will work good in a 300 ft drag? i have a 16 sprocket but i havent tried it yet, i will try with 16/38 first. With the 16/36, did u have to modify the chain any or kept the stock length? thanks
