Honda fourtrax 300 Noise??
Old Feb 3, 2003 | 08:30 PM
2strokeDiehard's Avatar
Default Honda fourtrax 300 Noise??
I have a 96 Fourtrax 300 that has a knocking noise in the top end? I'm fairly confident its the piston But figured I'd ask a few Questions! I have heard this same noise in one other fourtrax and thought maybe it was common? It only has 85PSI of cranking compression, I'm not sure what it should have but this seems low? The noise is a little deeper noise then a valve train noise. Anyone ever have this problem? Thanks for any info in advance!
Old Feb 3, 2003 | 09:32 PM
exforever's Avatar
ya i have a 300ex and noticed that noise as well. you have a loose chain or a loose bolt. try checking that and make sure everthing tight.
Old Feb 3, 2003 | 10:25 PM
BigAlCanada's Avatar
You should have at lease 150 PSI. If its really at 85, you need to rebuild you motor. I did myne 2 months ago and changed my cam chain also.
Divergent12
Dec 30, 2017 08:33 PM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
ScopeZ_
Jul 28, 2015 01:44 AM
hondarider1234
Jul 21, 2015 11:53 PM
