rancher dies when idling
Old Apr 20, 2000 | 04:20 AM
rancher's Avatar
I have a rancher i bought in november. since it was new if it idles for a period of time it dies. it is easy to restart, but does anyone have any ideas as to why? i carried it back to the dealer about two weeks ago and they said the mixture might be off in the carb. they adjusted it, but it still dies after about two or three minutes at idle. any suggestions would be appreciated.
Old Apr 20, 2000 | 04:26 AM
JRM's Avatar
JRM
without hereing it die myself i can only throw some guess's your way.
1. the idle is so low the compresson relece kicks in and kills it, (your would here clicking before it died)
2. the idle itself is just to low
3. the carb heat circuit is on causing a rich idle mixture
4. ?? alot of other things that I cant think of because it is late Anyone else have a idea?
Old Apr 20, 2000 | 10:06 AM
esears's Avatar
Check your choke cable/linkage. Maybe it's holding the choke closed just enough to load up the carb. It doesn't take much at an idle. Just a thought.
Old Apr 20, 2000 | 11:32 AM
snowshark's Avatar
Try bumping up the idle a little first. The idle adjustment know is easy to get to. Look in your owners manual for the exact location.
Old Apr 20, 2000 | 03:38 PM
Hondapride's Avatar
Yeh sounds like the idle is just to low.
turn the screw in the carb counter clockwise and is should idle higher.
Also do you still have the choke on after 3 min?
Old Apr 20, 2000 | 07:44 PM
JRM's Avatar
JRM
rember to tab the throttle as you turn up the idle..seems to make it adjust smoother
Old Apr 22, 2000 | 11:17 PM
rancher's Avatar
thanks for the input, i might give further explination. it dies when the machine has been warmed up and running for a period of time. i have the choke pushed completely off. i have idled the carb up so that it jumps pretty good when you put it in gear. but if i am out riding and stop to visit with someone and leave it running it will die after about 2-3 minutes at idle. as mentioned earlier it starts right back up easy enough but why does it die?? has anyone else had that problem or is it just unique to my machine? my 300 would idle all day, is this a rancher thing?
Old Apr 24, 2000 | 09:43 PM
aroostook's Avatar
1.Idle your rancher back down. 2 Try a split fire spark plug.3 Ignore slams about this post. I swear by them.
Rancher
Hi Lifter skid plates
Bear Claws
Winch
slowgsxr97
Mar 18, 2022 03:40 AM
Polarisman1123
Sep 13, 2015 10:06 AM
Knackknack
Aug 19, 2015 07:45 AM
house1
Aug 9, 2015 10:49 PM
binky79
Jul 30, 2015 06:37 PM
