k&n on rubicon
Old Apr 1, 2003 | 12:50 AM
stubblejumper's Avatar
Default k&n on rubicon
Is anyone here running a k&n on a rubicon with no engine mods?Does it require rejetting?Did you notice any improvement?
Old Apr 1, 2003 | 05:16 AM
slab's Avatar
im running it on mine and i noticed improvement when i put it in. i cant really say that it was a life changing kind of difference but a difference none the less
Old Apr 1, 2003 | 11:07 AM
Specta's Avatar
I have not put a K&N on my ATVs, I have put them on two on my vehicles, one modified one stock. What I have decided is that for a stock application, there is no improvement. If you have modified the engine so it requires more air flow, a K&N in a good upgrade.
Just my observation.
I definataly don't like the idea of the K&N air filter not doing a good job when first cleaned. It takes a little dirt in the filter to get it to filter good. When I take off the Honda filter and the inside of the carburetor bore is clean, that is more important to me than a little more power.
Old Apr 1, 2003 | 08:59 PM
dzzy's Avatar
It should run fine with the stock jetting. It would make most difference at high speed and rpm when the engine is consuming the most air. If you are interested in power, you might go up one size on the main jet. Get an OE Honda or Keihin jet for the most accurate metering. If the K&N flows more air, and your engine can use it, you need a little more gas. I largely agree with Specta tho, the job of filtering is more important than an HP here or there, in the long run.
shimanok2
Jan 29, 2016 07:37 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
colt1126
Aug 18, 2015 10:38 PM
