Rancher cold starting pain.
Old Jan 17, 2000 | 12:47 PM
BrianWSNC's Avatar
W-Danworth, if you spray or coat the cable with WD-40, or some light Engine oil, it should displace the water that is freezing inside the cable and keep it from freezing.. it's worth a try
good luck
Old Jan 17, 2000 | 02:49 PM
GlennS's Avatar
Went riding on Saturday. MInus 33 Degrees Celius. NO starting problems at all. Damn cold on the ride though!
Glenn.
Old Jan 17, 2000 | 03:05 PM
BigRed450's Avatar
Hi Terry
How are you? I was just checking through the forums here and saw that you were having starting problems. So far my 450es has always started with no problem. We have had temperatures downwards of -35 Celsius and I have yet to even need to use the primer. As one of the other fellas had mentioned turn the key on first, give it a second or two for the carb heater to start, then pull the choke and start. Do Not use the primer button unless it will not start this way ( primer is generally only needed if the machine sits for extended periods in cold weather). If you are still have trouble I would suggest taking the machine in to have the carb adjustments, choke cable, and carb heater checked. If you haven't taken it in for your first checkup yet that may be the problem. New cables strech and need to be adjusted. Hope this helps.
Ride the "WILD COUNTRY" , South Gillies, Ontario, Canada. Y2K Honda 450ES <a>The "BIGGER BIG RED"</a> <a>JJTH</a>
MikeyBoyesq
Nov 27, 2020 02:44 PM
Big600twin
Jun 10, 2015 03:01 PM
RedRancher
Jun 4, 2015 12:29 PM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
