13:1 piston 440EX
Old Apr 10, 2003 | 09:59 AM
Ernie660R's Avatar
Default 13:1 piston 440EX
Is there such a thing, 89 or 89.5mm piston. Need some help Honda people! Who makes them and who do I contact.
Old Apr 10, 2003 | 11:14 AM
smitty911's Avatar
Ernie,
IF you go that high in compression on a 440 you will have problems with the cases cracking. You sure you want to go that high?
Smitty
Old Apr 10, 2003 | 04:11 PM
RacinJason's Avatar
KABOOOM!
Old Apr 10, 2003 | 04:32 PM
Ernie660R's Avatar
I am just trying to help out a friend who wants to build a fast quad. He wants 13:1 period, I am trying to talk him out of it and just get a 11:1 because he likes riding real hard and does not take of it.
I will mention your comments to him smitty911, The Honda cylinder head and jug don't look like they could take a lot of abuse from a high compression piston. He blew the first head gasket with the 11:1, so I told him what makes him think that the 13:1 will hold.
Old Apr 10, 2003 | 06:07 PM
RacinJason's Avatar
You can lead a horse to water....
Old Apr 10, 2003 | 06:11 PM
KGB's Avatar
KGB
There is more to compression than just the piston. You need to consider the duration/lift of the cam too. If the valves are open longer and wider, than compression will be altered because of it.
Old Apr 10, 2003 | 09:30 PM
Ernie660R's Avatar
Very True sandneck, he did all the damage the first time with the stock cam. This time he purchased a stage two Hot Cams. I am going to strongly recommend staying with the 11:1 piston.
Old Apr 10, 2003 | 09:44 PM
RacinJason's Avatar
Why put the smaller of the two cams in if you want all the power you can get? Use that stage II cam
Old Apr 11, 2003 | 10:17 AM
KGB's Avatar
KGB
If you have a hot cam you probably have stock rockers, I wouldn't mess with something that high performance if you don't want to at least harden the rocker arms.
Old Apr 11, 2003 | 02:48 PM
RacinJason's Avatar
no need for hardened rockers with hotcams
