250ex twist throttle
Old May 10, 2003 | 10:56 PM
scosho's Avatar
Default 250ex twist throttle
I'm installing a motionpro twist throttle. The directions say to take the carb cap off the factory cable so I can use the stock carb cap and rubber sealing boot atop the cap on the new cable. But I can't get the %#&@## stock cap off the cable. Any ideas? The motionpro kit comes with a new cap but no rubber boot to seal the connection between the cable and cap, so I can't use the new parts without the rubber boot stuck on the stock cap assembly. Have I confused you? Thanks in advance for any help.
Old May 10, 2003 | 11:32 PM
KILLER250R's Avatar
You don't remove the cable from the top, use then one...wrap a piece of electrical tape around it...problem solved.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
hueby
Nov 6, 2015 11:34 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
89Lt250r
Sep 7, 2015 07:53 PM
