Hunting, Trapping, Game Management Discuss Bow and Fire Arm Hunting.
Box Scraper Experience
Old Oct 18, 2003 | 10:15 AM
rfrenchu's Avatar
Default Box Scraper Experience
Has anyone had any experience with using a made-for-ATV box scrapers? The ones that seem reasonably priced (less than $350) look chintzy and the ones that look heavy duty are quite expensive (over $1000) I'd like to level my back yard a bit but before I buy something I'd like to know if it works. The few I've seen are cheap, expensive, and horribly expensive
Naturally, I'd like to check out "cheap" first.
Old Oct 18, 2003 | 11:35 AM
UBETRUN's Avatar
Find 4 - 5 feet of railroad track (not ties, the metal rail). With a torch, blow a hole in the web at each end that's large enough to allow a heavy chain through. Run a single length of heavy chain through both holes and fasten it to itself sort of snug against the rail web. With a strap and hooks, you can adjust the drag angle by moving the hooks along the chain toward one end of the rail or the other. I used two hunks of track, each 6 ft long, behind a Toyota T100 4x4 to rebuild a road that wound up a mountain. The first couple of passes were easy, only the center of the road was dragging. After half a dozen passes, both peices of rail were level and tearing the hell out of the first 4 inches of topsoil across the full width of the road. That little Toyota never worked so hard in its life:-) 4x4 low bucking its way up a mountain in first with a 600 lb anchor. You can get scrap railroad track at any small railroad for cheap. Smaller hunks make great little anvils.
Customer Service #1
May 15, 2020 08:46 AM
Johnny Mac
60
Dec 14, 2019 06:13 PM
Levi Enstad
Sep 26, 2015 05:36 PM
kampswas
Sep 23, 2015 05:05 AM
jankerstien
Sep 21, 2015 03:09 AM
