warn works winch problems
Does anybody have the warn works 1700 or 3700 winch? I've had problems with the freespool cam not reingaging. This makes it skip as the load increases, eventually causing the winch to fail. I use my winch on a small logging arch with a ****** block. I can't believe that i'm working it too hard, afterall, how much can a log weigh? please respond if you've had problems with this series.
May 27, 2015 11:15 AM
