Hunting, Trapping, Game Management Discuss Bow and Fire Arm Hunting.
Buck Jam
Old Jul 24, 2005 | 12:32 PM
SPORTSMAN70003's Avatar
Default Buck Jam
Anyone ever use any Buck Jam? How good did it work?
Old Jul 25, 2005 | 12:59 PM
okiedude's Avatar
Default Buck Jam
I have never heard of it. Sorry
Old Jul 25, 2005 | 01:32 PM
RedGoblin's Avatar
Default Buck Jam
Is that the stuff that has different flavors like apple, corn, etc? The only time that could possibly really work effectively would be in the earlier part of the season when deer are still going to food sources like clockwork. Just set up by a food source, whether it be crops or mast (acorns, hickory nuts, etc.) and you'll get the same, if not much better effect in the early fall. Don't waste your money on it.
Old Jul 25, 2005 | 01:37 PM
Default Buck Jam
I put some out last weekend and will let everyone know how it does.
Old Jul 25, 2005 | 10:07 PM
RedGoblin's Avatar
Default Buck Jam
What flavor? How did you put it out? Are you going to look for sign around the area you put it out or how are you going to judge if it works?
Old Jul 25, 2005 | 10:18 PM
Default Buck Jam
I used apple flavor and put it right next to a soybean field where I have been seeing a few deer. I'm the only one that hunts this spot and I know it holds deer. I placed it about 10 yards from a deer trail. I raked back the leaves and poured it on the ground like the instructions said.
Old Jul 26, 2005 | 11:40 PM
RedGoblin's Avatar
Default Buck Jam
Any luck?
Old Jul 31, 2005 | 09:57 AM
oneshot7525's Avatar
Default Buck Jam
I tried that stuff last year up here in wisconsin with mixed results. I used it during the early season next to a field with no success. I had the apple flavor and set up on the edge of a corn field. I had numerous deer walk right by without even smelling it. I think they had the corn field in their mind. I had the most success during late season when there was snow on the ground. I placed some of that goop all over branches as high as I could get it so the wind would take it and I had deer on their hind legs trying to get at it, quite a sight. IMO I would put a little out to use like a cover scent because that stuff is strong.
Old Jul 31, 2005 | 10:36 AM
Default Buck Jam
I'm going to go hang my treestand in that area and will check to see if its working.
Old Jul 31, 2005 | 10:51 PM
RedGoblin's Avatar
Default Buck Jam
If there's no tracks around then I would say it's not.
