Hunting, Trapping, Game Management Discuss Bow and Fire Arm Hunting.
Tire Pressure
Old Feb 28, 2001 | 12:06 PM
sheepfarmer's Avatar
What do you normally run for a tire pressure on your wheelers? I just blew mine up to 10 psi, mainly because that's as low as my car-tire gauge will go.
Also, I'm assuming there has to be a low-pressure gauge out there somewhere for flotation tires. Any sources?
Old Feb 28, 2001 | 12:36 PM
Camo-man's Avatar
I run 4.5 lbs in my tires ,,, and yes there are low pressure guages out there....
Old Mar 1, 2001 | 12:56 PM
Farmr123's Avatar
I run between 4 & 5 pounds. A low pressure guage came with both of my quads. I'm sure that your dealer would have them on hand or could get one. Too much air in the tires will make them less puncture resistant.
Old Mar 18, 2001 | 05:12 PM
Silverfox2's Avatar
The owner's manual with my old 1986 Kawasaki Bayou 300 says to maintain 3 psi on the tires. I would imagine the higher the pressure the stiffer the ride will be because you get less shock absorbing effect from your tires.
Old Mar 21, 2001 | 10:40 AM
polarisz71's Avatar
I run about 51/2 to 6 pounds in mine because I have a leaky tire and I want to make sure it has plenty of air.
Old Mar 22, 2001 | 12:38 AM
cowboy's Avatar
Any luck finding a low pressure guage yet? On the stock 489's, I run around 4-5lbs. to maintain a smooth ride. However, in my 27" 'Claws, I run 6.5 up front to handle the heavier weight, and 6 in the back.
Best of luck,
mike
Old Mar 22, 2001 | 08:13 AM
I finally broke down and bought a pencil type from Wally World. I really wanted a dial type, but the only one I could find was from Cabelas, and cost about 3 times what I thought it was worth.
Thanks for all the replys. I'm running about 5psi now, and will adjust as experience dictates. I'm liking the easier steering from the slightly higher pressure, but mud season is here, we'll have to see about flotation.
Old Mar 22, 2001 | 11:48 PM
TEXASCAT's Avatar
hey did you know that the pakistani people now have a new use for sheep??
wool.
Old Mar 23, 2001 | 07:59 AM
Ya mean they're not just for breakfast anymore? ":^)
Old Mar 23, 2001 | 10:27 PM
TEXASCAT's Avatar
no, more like entertainment when the male to female human ratio is like 100:1.
