easy help
Old Aug 8, 2009 | 08:27 PM
exfever's Avatar
Default easy help
Hello I have a 02 400 ex just bought it 300 bucks did a valve adjustment and now it runs perfect except for it does not idle , only when the choke is all the way on if i move the choke off even a little it kills it and if i keep it reved with choke off it will stay running so wich screw will adjust the idle. any help is good thanks
Old Aug 8, 2009 | 08:30 PM
exfever's Avatar
Old Aug 9, 2009 | 03:56 AM
faruquehabib's Avatar
welcome to the forums!!
Old Aug 9, 2009 | 09:20 AM
HawkeyeRider's Avatar
Welcome to the forums. A little suggestion...you might get a better response if you post your question in the Honda section. Good Luck!!!
Old Aug 9, 2009 | 11:01 AM
sdm111's Avatar
2 strokes or 4
Usually when it only runs, idles on choke it means that the pilot jet is clogged. If I were you I would take the carb. apart and clean or rebuild it. Make sure to clean all the passages also. Can't remember where the idle screw is been a while since I had a 400ex.
Old Aug 10, 2009 | 07:26 AM
BioWare's Avatar
Toxic Ryder
Welcome
exmotocrosser
Sep 13, 2019 06:12 AM
mrtidy
Feb 3, 2016 05:00 PM
exmotocrosser
Sep 26, 2015 08:18 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Rick Van Matre
Sep 11, 2015 11:52 PM
