New From Louisiana, need info.
Old Sep 8, 2010 | 12:38 PM
rwc_critter's Avatar
Default New From Louisiana, need info.
I experienced a problem with my 09 Prowler jerking when you try to take off from a dead start or at a rolling start. It did not do it when in 4 wheel drive. I discovered that the rear driveline was turning as much as 3 or 4 revolutions before rearend would engage. This machine has the turf saver rear differential. I removed the rearend and found that the spool was welded so you could not take apart. I ground the welds off and dissassembled and found that there are a type of clutch pack on each side. Mine was damaged beyond any repair on one side. So to make a long story short I was wondering if anyone has removed there turf saver and installed a solid spool from a older model. If so do you have the correct part #'s. The turf saver spool and gear assembly is upwards of $700.00 everywhere I have looked online and the comparable solid spools are around 150.00 in the older models. I have compared the parts diagrams and numbers to several other models and everything seems to be the same except for the pinion tooth numbers and the spool with the ring gear. My pinion is 10 tooth and the ring gear 36 tooth. I can't afford to spend 700 plus dollars to repair this rearend so any help would be appreciated.
Old Sep 8, 2010 | 01:36 PM
DODGE57HEMI's Avatar
Mopar Man!
Welcome!
Old Sep 8, 2010 | 01:38 PM
BioWare's Avatar
Toxic Ryder
Welcome
Old Sep 8, 2010 | 01:41 PM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Don't have any experience with that myself. You might want to post this question over in the Arctic Cat section and see if anyone has done this before.
Old Sep 8, 2010 | 03:32 PM
Old Sep 8, 2010 | 07:10 PM
faruquehabib's Avatar
welcome!
panicmanic
Aug 3, 2015 10:49 AM
TXRIDER
Where to Ride
May 13, 2001 11:48 PM
FMFBlasterMX2
Where to Ride
Aug 3, 2000 01:39 AM
