New with tire related question
Old Dec 17, 2010 | 09:33 AM
wnyhuntermike's Avatar
Default New with tire related question
Hi all,
I'm usually not a big atv forum guy, but am starting to have some questions and this looks like the place to find answers! I mostly just use my atv on my own property here in western NY for hunting and work around the farm. After a few walks out from deep in the back 40 to get tools and such I started researching tire Slime, Tire *****, etc. online. I ran across foam tire inserts called Flat Tire Defenders and I'm wondering if anyone has experience with them?
I just have an older Suzuki 250 4x4 and put some new Kenda's on but the occasional nail, fence line, etc. makes me want to run something to be able to ride the machine out and be able to repair it at the barn if I get a puncture. I guess I like the concept of these over Tire ***** because if I puncture a Tire Ball I need to break down the tire to repair it, where these foam inserts look like I could just plug the hole, add air and be done... I've stayed away from Slime because it's not cheap and I've heard it's messy, doesn't protect the sidewalls, etc. (Man I guess I've learned a lot being a lurker!)
Any thoughts or experience? I appreciate it! Next question will be cv replacement... I have one boot that just broke but it's too cold to work on it now! I'm saving that for spring...
Thanks!
Mike
Old Dec 17, 2010 | 10:14 AM
mudslinger2's Avatar
I haven't been stuck since the last time!
Default Tire Plug Kit
Do you regularly carry a tire plug kit with you? You can buy the kits from most outdoor stores for next to nothing and they seem to work well. It just comes with the plugs, rubber cement, and tools to put the plugs in. I also carry a small 12 volt compressor to blow the tire back up when I am done. I think that I got both the tire kit (cabelas) and the compressor (walmart) for less than 25 bucks total. The tires that I just replaced (b/c of tread) had three plugs in one tire and still held air without an issue. May be a cheap solution rather than spend whatever amount on the other solutions. Good Luck.
Mudslinger2
Old Dec 17, 2010 | 10:44 AM
Thanks mudslinger2! I have a plug kit, compressor, etc. but not always with me. I guess the appeal to me was the convenience of not having to fix it right then and there on the spot. Cost is less of an issue than time. (I only mentioned the cost of the slime because it was more than I expected, and doesn't protect sidewall cuts).
Generally I have a big tool box on the rear rack with all sorts of stuff in there but it's usually that 1 in 100 times I either remove the box (generally during hunting season) or used the compressor for something else and forgot to put it back that I get a flat. Murphy's law it's never when I'm prepared or have time! Always late in the day or when I'm rushed!
The big appeal to me with the flat tire defenders was that it appears I could finish whatever I'm doing and come back to the repair when I have time. Between tractors, atvs, bikes, etc. something usually has a flat at any given time. This would just rule out the atv! I have used Michelin Mousse inserts for my motorcycle but only recently and I wish I would have tried them years ago (but never had money when I was young and racing!) So when I found these, they made perfect sense to me...
Again thanks for the reply! I guess I'm just looking for that extra insurance policy that I don't have to think about when I grab the wheeler to do something.
Old Dec 17, 2010 | 10:45 AM
P.S. Great picture in your signature!!!
Old Dec 17, 2010 | 12:06 PM
ba300's Avatar
Orginal Trespassers
Welcome to the form
I took some pvc tube and mounted it to my quad then put a bike co2 tire inflatter and plug kit in it. takes 5min. done works great under $20
I use a paint ball co2 now dose 5 tires the bike has a small co2 one tire each.
Have the same set up on my 4x4 as well
Old Dec 17, 2010 | 12:21 PM
ba300's Avatar
Orginal Trespassers
I have read this stuff works great
High Lifter Products - Tire Sealant
Old Dec 17, 2010 | 05:23 PM
In that picture I had gotten stuck first...when my brother got done laughing, rather pull me out he decided that he would get in the mud too and roost me...he got stuck before he could get far enough to roost me! Made for a good picture at least. Thank goodness for winches!
Old Dec 17, 2010 | 06:28 PM
ba300's Avatar
Orginal Trespassers
sorry my pics where deleted they showed what it looked like.
i need to learn how to post pics better.
Old Dec 17, 2010 | 06:29 PM
ba300's Avatar
Orginal Trespassers
great pic.
Old Dec 17, 2010 | 10:22 PM
BioWare's Avatar
Toxic Ryder
Welcome
