have alot of vibration
Old Mar 4, 2012 | 05:39 AM
donnie4174's Avatar
Default have alot of vibration
Got a 150 coolster has alot of vibration when you rib it or riden anyone have any ideals
Old Mar 4, 2012 | 07:24 AM
Jaster94's Avatar
rib it? do you mean rev it? gun the throttle?
well anyways, check your motor mounts. make sure the bushings are in there and the bolts are tight enough and not shaking violently. double check the main frame and make sure the frame has not developed any cracks or has broken.
Old Mar 4, 2012 | 08:48 AM
donnie4174's Avatar
Default ok riv it lol their isnt any bushings on the motor mounts
i have checked the frame cant find no cracks anywhere
Old Mar 4, 2012 | 09:12 AM
Jaster94's Avatar
how's the motor mount bushings? does it idle rough or is it smooth?
Old Mar 5, 2012 | 06:18 AM
donnie4174's Avatar
it idle smooth and runs grate i bought this bike the motor mounts was broken i welded them back in place the guy said its always had vibration their is no ruber on the motor mounts at all i was thinking about cutting them off and weld them on so i can put some rubber between the motor and frame other then that is a grate bike its a Coolster 150 it has lots of power
Old Mar 5, 2012 | 06:19 AM
donnie4174's Avatar
also u can feel the vibration mostly on your feet
Old Mar 5, 2012 | 07:30 AM
scootergptx's Avatar
Supersock
Hired Gun!
If there isn't anything but metal connecting the motor to the frame, you should feel a lot of vibration.
Old Mar 5, 2012 | 08:08 AM
BioWare's Avatar
Toxic Ryder
Welcome
Old Mar 5, 2012 | 08:12 AM
Welcome.
Old Mar 24, 2012 | 08:01 PM
MarcBegan's Avatar
Default New ATV
Hey Hey what would be the best ATV for a newbie? I wanna tear the streets up lol in a thongue lmbo.. Ok maybe not the thong
