JCL/Buyang 550 Alignment
Old Sep 17, 2012 | 12:53 PM
bibarnes's Avatar
Question JCL/Buyang 550 Alignment
I have 2 small problems,. The first I can fix with some string and a ruler and that is a toe problem. The second has me befuddled, camber. Both front wheels are 1/2" off vertical in the same direction. They lean to the right. The shock asembly is connected at the top just like a car with a single threaded connection and a castle nut.
Any ideas/suggestions???
TIA
Bill
Old Sep 19, 2012 | 04:31 PM
bibarnes's Avatar
Default alignment
I am an idiot. I failed to check the air in the front tires. RF 3.5psi LF 9.5psi duuuuh. I always preach "look at the simple things first." I need to start listening to myself.
Old Sep 21, 2012 | 06:55 AM
BioWare's Avatar
Toxic Ryder
Lmao
Old Sep 21, 2012 | 04:54 PM
bibarnes's Avatar
Default Duuuh
You need to be kind to your elders.
I do have another problem and this one is real. The linkage locks up on the shifter too often. I have to get out pliers and wiggle the linkage where it enters the tranny. I have seen the inside of the linkage at the shifter end and see that if the low range rod moves a little bit it locks every thing up. What I am not sure of is how to prevent this. I am assuming that a simple adjustment of one or both of the connecting rods is in order, but I am a little hesitant to jump in and possibly make it worse. Does anyone know what to do? BTW the linkage on the 550 is identical to the 300.
Canamaniac!
Sep 15, 2015 06:19 PM
GerrBear
Jan 3, 2002 01:36 AM
fuddrucker
Dec 19, 2001 10:35 AM
walexa
Jul 17, 2001 01:57 PM
Electric350
Apr 25, 2001 10:05 PM
