1991 Polaris trailboss 250..Need help!
Old Feb 23, 2014 | 09:40 PM
Cam-Luvs-Atv's's Avatar
Default 1991 Polaris trailboss 250..Need help!
Hi, I'm new to this forum. My 91' trailboss 250 has trouble starting..but once started it runs great. When I take out the plug and pull 10 times and get the gas out and put it back in it will try to start but it won't quite go.. After that I undo the springs holding the manifold on. I take the manifold off and pull it a few times and It will start. Once it's started I put the manifold back on and it still runs great.. I feel this is to much work to start it and there must be something wrong. Please help!
Old Feb 24, 2014 | 06:47 AM
Welcome .. Sounds like you're flooding the crank case from a worn/sticking float needle. Probably time for a carb kit that includes a new needle and seat.http://www.ebay.com/itm/Polaris-Trail-Boss-250-1989-1990-1991-1992-1993-Carb-Kit-/400644377894?pt=Motors_ATV_Parts_Accessories&hash=item5d48440d26&vxp=mtrPlus not a bad idea to check compression also. If lower than 115 psi,carb kit may not help.
Old Feb 26, 2014 | 11:47 AM
BioWare's Avatar
Toxic Ryder
Welcome
Old Feb 26, 2014 | 02:33 PM
Welcome to the forums.
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
binky79
Jul 30, 2015 06:37 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
Gnuters
Jul 19, 2015 10:03 AM
