Thanks for the add! Please help me with my daughters atv.
Old Apr 7, 2016 | 08:58 AM
Poorboy04's Avatar
Default Thanks for the add! Please help me with my daughters atv.
I have a Tao tao 110 that wouldn't charge the battery. So I replaced the stator and regulator and now it will only charge at 13.1 volts at full throttle. (Maybe I got a bad regulator off of eBay). Also if I turn the head light switch on it will automatically drain the battery to 8 volts or lower (While the atv is running). The headlights are pulling so much it actually melted the housing. The next problem I'm having is the atv will just click and not turn over with a fully powered battery. I have checked the solenoid and it's working and putting 12 volts to the starter. But the starter only works when it wants to (I have checked all the grounds and connections and can't find any loose. Please help me I work on this atv more then my daughter gets to ride it.
Old Apr 7, 2016 | 10:41 AM
Welcome to the forums.
If you haven't already asked, try the Chinese ATV section.
Old Apr 7, 2016 | 02:47 PM
Poorboy04's Avatar
Where is that section I couldn't find it in the forums.
Old Apr 7, 2016 | 05:11 PM
Chinese Quads - ATVConnection.com ATV Enthusiast Community
toonces
Mar 14, 2016 10:42 PM
Ride 4 Ever
Technical and How-To Articles
Jan 29, 2016 01:27 PM
topkick857
Jan 27, 2016 09:10 AM
jeffreybandel
Jan 18, 2016 04:49 PM
ritchierich
1) Engine problems..
Jan 13, 2016 02:57 AM
