400ex
Old Sep 19, 2016 | 07:53 PM
Kole123's Avatar
Default 400ex
I have a 2006 Honda 400ex and was riding it and it quit when I slammed my brakes and clutch because there was a tree on the trail and when I tried starting it back up it was knocking but once it cooled down it turns over but won't start.
I've got spark compression timings good and electrical good I cleaned carb and even tried with starter fluid but still won't fire any suggestions
Old Sep 20, 2016 | 03:28 PM
DirtDevil101's Avatar
How did you verify spark/compression/timing?
If you have truly verified those it should run on SF...
Did you check your valves? Where was this "knocking" coming from?
Old Sep 20, 2016 | 09:34 PM
Kole123's Avatar
Default 400wx
I checked spark by taking out plug and see if it gave off spark and I put a new plug I checked timing by see if the cam was lined up with the T mark on side of motor. I used a compression test tool and it was all good and still wouldn't fire. I did not check valves and I couldn't really tell where knocking was coming from I think top end but not positive
Old Sep 21, 2016 | 10:55 AM
Good strong blue spark or something else??
Yeah...I'd rotate the crank and ensure those valves were opening/closing properly...knocking could have been in head...
Old Sep 21, 2016 | 03:36 PM
Kole123's Avatar
Ya the spark was good blue and I'll do that but it was getting real hot before that all the time
Old Sep 21, 2016 | 03:59 PM
Well...getting hot is what air cooled motors do...did you check your oil? I'd drain & check for metal particles if you think there was a pump failure...
Old Sep 21, 2016 | 04:04 PM
Kole123's Avatar
I drained it and it was low but seemed clean
Old Sep 22, 2016 | 07:11 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Old Sep 22, 2016 | 12:30 PM
Did you check the operation of the valves?
Old Sep 22, 2016 | 02:44 PM
Kole123's Avatar
Default Not yet haven't got the chance to
