400ex
Old Sep 26, 2016 | 05:34 PM
Kole123's Avatar
bAd news only 35 psi of compression
Old Sep 27, 2016 | 12:22 PM
DirtDevil101's Avatar
??? - I thought you had already confirmed! No matter...it's not bad news, but rather a direction to remedy...and an opportunity to learn more about the machine if you choose to tackle this yourself (if you're a seasoned mechanic please disregard
Old Sep 27, 2016 | 09:14 PM
Kole123's Avatar
Found problem I melted piston and so I put new one in top end is all cleaned up I put it back together and it still won't fire only pops every so often
Old Sep 28, 2016 | 10:55 AM
When you say "I put a new one in"...exactly what did you do? Hopefully not just slap another piston in...
Regardless...did you confirm compression after the piston swap? Almost starting sounds like barely not enough compression to run...
Brandon420
Jul 18, 2016 11:45 AM
500sportsman2002
Jun 29, 2016 02:39 AM
Mrb24
ATC 3-Wheelers
Jun 28, 2016 03:38 PM
mthonda400ex
Jun 25, 2016 01:20 AM
Chris.400
Jun 23, 2016 08:54 PM
