meerkat 50 runs a few seconds
Old Aug 22, 2020 | 11:22 AM
8up4wheel's Avatar
Default meerkat 50 runs a few seconds
Tom with meerkat 50 that just stopped running while idle
Old Aug 22, 2020 | 12:42 PM
8up4wheel's Avatar
meerkat 50cc with approximate 200hrs died while at idle
runs a few seconds then dies -restarts then dies,cant use choke to keep running,throttle push kills it immediately
Changed with new: carb,cdi,magneto/pickup assm,voltage regulator,
Old Sep 19, 2020 | 03:51 PM
boulderboy's Avatar
I had the same problem with my Meerkat 50 resurrection for a while, changed the same parts you did, in the end I checked the valve clearances (very roughly as I didn't have a proper feeler gauge at the time), turned out the valves were never quite shutting fully. Loosed off the rockers and retightened them so that I could 'just' feel the slightest touch of clearance on the compression stroke. Ran fine after that. I heard in a pinch, a coke can is made of metal about 4 thou thick, can be used as the roughest of feeler gauges..
Old Sep 21, 2020 | 06:33 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Bu4x4Boy
May 3, 2005 11:52 PM
quadkid9d
KTM
Apr 23, 2005 01:35 AM
htloi
Dec 24, 2003 08:10 AM
Cat500i
May 23, 2003 11:43 PM
