92 Suzuki 250 LT-F4WD electrical start
Old Apr 10, 2022 | 01:34 PM
Delftblue60's Avatar
Delftblue60
Default 92 Suzuki 250 LT-F4WD electrical start
Hi group,
Hope all is well.
I put a new battery in my 92 250 Quadrunner and electric start worked again. My machine sat idle/unused in shed for past 7 yrs. Just slowly reconditioning and fixing what needs to be fixed.
Anyhow, the battery died as it was below zero degrees and I'd left my machine untouched for a few weeks. Tested new battery. 12 volts no problem but still took it indoors to put trickle charge on it. Reinstalled, not working. Put in new 20 amp fuse as I noticed the one (in receptical left side when facing front) had blown. Tried 15 and 30 amp as it was all I had at the time. They blew immediately. Bought new 20 amp fuses and checked wiring. Loose connector underneath so I repaired it. Fine. Not blowing fuse anymore, lights come on weakly (when running after pull start) but electric start will no longer work. Any advice would be greatly appreciated.
Thank you
Old Apr 11, 2022 | 05:31 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Old Apr 11, 2022 | 05:32 AM
Supersock
Hired Gun!
Try posting this in the Suzuki section. Not many look in here and they'll be able to help you out.
John-Lennon
Sep 5, 2019 02:22 AM
pvillefball421
1) Engine problems..
32
Mar 15, 2012 04:05 PM
eitok
Oct 18, 2010 11:19 AM
luvinlife
Sep 2, 2008 04:09 PM
Louk
Aug 27, 2007 09:50 PM
