2007 Polaris sportsman 500 efi starts then dies in 3 seconds
Old Feb 5, 2024 | 11:42 AM
Ethan Hill's Avatar
Default 2007 Polaris sportsman 500 efi starts then dies in 3 seconds
Hi I am new here I have a 2007 Polaris sportsman 500 EFI H.O It starts then dies in 3 seconds and when you give it throttle it just Boggs down and dies and backfired and sometimes when you try starting it for a while white smoke will come out of the throttle body, and when you let it idle it does the same thing and I already tried adjusting the cable tension and checked the gap and the thumb throttle box.
New Quantum Fuel System injector, Fuel Pump and Fuel pressure regulator basically the whole fuel pump replaced K&N Fuel filter K&N air filter, K&N oil filter, oil change done 20 miles ago New fuel lines and It does the same think when the air box and all of that stuff is off This is the second injector I have bought and like the 20th spark plug and the seconds fuel pressure regulator to, I honestly don't know whats wrong with it, it could just be something small or something big idk.
Please respond I have wasted a lot of money on this atv and I don't know whats wrong with it.
Old Jul 3, 2024 | 12:54 PM
Sportsman102's Avatar
Default Have you fixed this I am having the same issues hoping you found the result thanks
****** have you figured this out yet****
Last edited by Sportsman102; Jul 7, 2024 at 09:26 AM. Reason: No answer—-more texted
Old Apr 19, 2025 | 06:15 PM
Sportsmanryde's Avatar
Default Did you ever figure it out?
Did u ever figure out the issue? I am having the same isssue can’t figure it out.
scubasteve3178
Apr 5, 2020 08:53 PM
Rescuedog9
Aug 6, 2010 02:55 PM
sanders1021
Feb 9, 2009 10:10 PM
theBIRD
Feb 19, 2008 04:34 PM
DEER HUNTER
Nov 12, 2007 07:07 PM
