Loud high pitch squealing noise coming from P650
Subscribe
Jun 30, 2003 | 08:26 AM
About 1800 km's or close to 1200 miles I think
Reply 0
Jun 30, 2003 | 08:53 AM
Quote:
Originally posted by: STAKK
The bearing on the clutch cover is bad, you will see it as soon as you remove the cover, the EBC plastic fork presses against it to put pressure on the belt, and unless the fork is against it it doesn't move, therefore it won't make the sound, mine was worse when i was slowing down below 10 mph, I replaced mine after 2500 miles, you have to get the whole cover as the bearing and cover are one part's piece, if you don't have any warranty left it will cost about 60 buck's......
You can carfully remove the the bearing with a little work and press a new one in, the bearing is $3.75, it has been done and worked just like new.
Reply 0
Jun 30, 2003 | 10:53 AM
I found this information on the Highlifter forum, sounds like the bearing can be replaced very easily. Will have to take it apart again and take another look.
Sounds exactly what I just had happen to me last night. I removed the clutch cover and found the bearing on the end of the drive clutch where the fork of the engine brake actuator comes in contact with the clutch setup and not turning.
What I did was remove the bearing from the clutch cover. I was very careful and popped out the seals from the bearing without damaging them. Some how dust had gotten by the seals and mixed with the grease and turned to putty and stopped the bearing from turning. I cleaned the bearing with brake cleaner and repacked with grease. Put everything back together and now noise is gone and back to normal.
In cas anyone needs the part number from the bearing NSK 6907DDG and the number on the seal is 6907DG8. Not sure why there would be different numbers, but that is what was there. Kawasaki doesn't offer the bearing by its self. You have to buy the cover to get the bearing. I would think that a bearing supply would have it available but I didn't check.
Reply 0
Jun 30, 2003 | 04:09 PM
Thank's Kawadan, I knew the bearing was the problem, but didn't know it could be replaced or re-packed, that will save alot of money for us Prairie owner's..........
Reply 0
Jun 30, 2003 | 05:23 PM
  #15
STAKK
Where is the bearing located? I checked inside the cover and I see the 2 pronged fork, but no bearing? Is it a big or small bearing?
Reply 0
Jul 1, 2003 | 10:26 AM
  #16
TTT
Reply 0
Jul 1, 2003 | 04:44 PM
  #17
It's on the front clutch itself, right in the middle of the clutch with a bolt going through the center to hold the clutch on, you'll see the bearing and the cover has about 608 bolt's holding the cover on the clutch/torque converter........
Reply 0
Jul 1, 2003 | 04:48 PM
  #18
I meant 6-8 bolt's holding the clutch cover on........not the black housing that cover's the clutch but on the clutch itself........
Reply 0
Jul 2, 2003 | 12:50 PM
  #19
Kawidan,
The cover that Stakk is referring to is the one that actually holds the primary spring in place. It has 8 small bolts holding it onto the primary clutch assembly. Also, I think your looking for a worn bushing in that cover and not an actual bearing.
Reply 0
Jul 2, 2003 | 09:23 PM
  #20
Scotia650
I took the cover off tonight and cleaned the bearing as best as possible. Put everything back together and went for a good 20km ride and everything seems fine. Hopefully this will hold up until I can get it to the dealer to get the cover replaced.
Thanks for all the info guys
Reply 0
