Mojave Snorkle Diameter
Old Jul 1, 2003 | 11:48 AM
HareScrambleRacer's Avatar
Default Mojave Snorkle Diameter
Can anyone tell be what the snorkl diameter is on the Mojave? I didn't get a chance to measure it, and I want to have Outerwears custom manufacture an outerwear to fit over my snorkl.
Thanks!!
Old Jul 1, 2003 | 01:31 PM
boob's Avatar
all i know is the carb diameter which is 2 1/4 inch, this is the where the airbox clamps on to the carb back, hope this helps
Old Jul 1, 2003 | 01:52 PM
Thanks for the info Boob....unfortunately I'm looking for the diameter of the snorkl inlet (under the hood). Since I'm not sure how much protection a clamp-on would have during a hare scramble, I'm going to trim my snorkl inlet, cover it with an Outerwear, and install my Smoothy hood.
Old Jul 1, 2003 | 04:47 PM
boob's Avatar
well in that case i wouldnt worry about the snorkle tube, if you cut it back it wont take away from performance and it wont add any to it also all the air from the snorkle is fed through your current air filter anyways, if you have stock setup that is, so all you would have to do is trim it back and put the hood on. Your current filter will filter out the snorkle air, if you want to do it anyways perhaps you could buy some foam and pack it into the tube which would be easier than a outerwears but trust me you dont need a filter, hope this helps
toonces
Aug 13, 2015 01:48 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
Zorro
Mar 6, 2001 04:17 PM
4Tecate
Jan 17, 2001 02:36 PM
