lakota sport and mojave
i have a race ready mojave, if you will, there is a picture at kawieriders .com and go to forums on the top and then go to mojave and lokota and go down to "my mojave" and i have links to where my pictures are also you can check out the picture gallery and see some of the most modded lokotas and mojaves with lurches 330 mojave
well you can do it yourself or have a good machine shop do it, if you were a welder you could do it in a breeze, so check your local machine shops or something, im taking welding here in 10th grade so ill post something if i learn a good deal there was one on ebay a while back under mojave but i dunno if its still there
i was just telling him a good alternative to shellling out alot of money for a swingarm, a proper weld will hold up stronger than the base metal, so in this case the first thing to go would be the original swingarm material not the weld
for taller handle bars your going to need riser bars, ill look for a link to one, also you can race cut your plastic by yourself with some sandpaper a marker and a hacksaw if you want to persue that then tell me and ill try my best to help, if you want to buy them ill get a link and post it for you
This is the link to the race cut plastic,
www.maier-mfg.com go to ATV then kawasaki, then lakota they sell lots in differant colors including orange that are race cut
i dont know the exact link because i dont know your preferance tho , but, www.denniskirk.com and then go to off-road and then to handlebars and controls and then go from there, i would do universal bars because not to many are made specifically for our machines, hope this all helps
