Vforce Dyno run
Old Jul 26, 2003 | 10:36 PM
  #21
VforceStan's Avatar
Default Vforce Dyno run
The best run was 38.1 hp and 33.4 ft lbs torque. This was NOT using any DynoJet part what so ever. Using the DynoJet kit, I got the best of 37.82 and 32.8 Ft Lbs Torque and the AF Ratio was ALL over the place. You can make the the dynojet kit as rich or lean as needed. This reitterates, through out all the years of trying to use DynoJet kits, you can never adjust with any consistancy. I have the runs to prove it again.....[img]i/expressions/face-icon-small-sad.gif[/img]
Old Jul 28, 2003 | 09:48 AM
  #22
bbertram's Avatar
Did they give you any print outs? I would like to see your best run on the graph.
Old Jul 28, 2003 | 10:07 AM
  #23
VforceStan's Avatar
Unfortunately, there were no printouts. His printer was not working. I did get all the Dyno Run files. I can use the RunViewer from Dynojet and print one out myself. All they show is HP. The sharware version doesn't show torque or AF Ratio...which is absolutely useless when trying to conclude results.
Old Jul 28, 2003 | 10:12 AM
  #24
bbertram's Avatar
I just like to see the pretty red line go across the screen...hehe. I can imagine the rest.
Old Jul 28, 2003 | 10:25 AM
  #25
VforceStan's Avatar
No problem....I'll print it out and scan it after lunch. Can it be posted somewhere on this forum?
Old Jul 28, 2003 | 10:35 AM
  #26
bbertram's Avatar
You can put it under your name, click on My Page and I think there you can add pics.
Old Jul 29, 2003 | 03:14 AM
  #27
tmm2good's Avatar
You guys are making me nervous, I just got back from riding at 8000 feet and my V was backfiring and sputtering, so I checked the jets, and it is jetted for sea level (why did I believe the salesman when he assured me they jet them for this altitude [img]i/expressions/face-icon-small-disgusted.gif[/img] ), So anyways I went and ordered the jet kit off of rocky mountain atv. It says its a K&N, but from what I have read it is a dyno -jet kit. Should I cancel my order and buy factory jets for this altitude or go ahead with the jet kit. ?
Old Jul 29, 2003 | 09:48 AM
  #28
bbertram's Avatar
From what I have read, I would not buy dynojets. Go for the brand alltoys ( i think he said it) recommends.
Old Jul 29, 2003 | 10:02 AM
  #29
VforceStan's Avatar
The Dynojet kit offered an inconsistant A/F Ratio. They do make a little more power than OEM jetting. I tweaked the OEM jetting and the airbox....slightly and acheived the same if not better results. It also maintained a consistant A/F ratio with Kehein jets. I tried to post my dyno run...the gallery is still saying..."pending review". Whats up with that????????????????????[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jul 29, 2003 | 10:04 AM
  #30
bbertram's Avatar
The boss needs to review your pics to see if they are suitable for viewing, thats all.
