KFX700 - Bad Choke Cable
I was having issues with my idleing. It would run good, but as soon as I stopped it would die. Tried everything that I could think of but no luck. Took it into the dealer and found out that the choke cable had to be replaced...........FYI
Common problem with eary kawi 650 was choke cable, then we found that the enrichener valve springs were weak and had to be replaced. It will be interesting to see if this will be a widespead problem .
