Pyer!!!!!!
Clutch spring by far is the best mod at the moment for the V possibly better than snorkel or exhaust because the factory detuned the quad with the clutch spring and the cdi.
By just adding a new 20$ clutch spring you will gain better accell and top end because it will allow the trans to shift at a higher rpm than stock which mean's you will have better accell out of ea gear and will let it eat on the top end more.
The cdi also retard's timing so bad that it is killing the V but at the moment we have no other choice over stock Diamond G (due out approx 2 months) is working on a performance cdi and also Vortex (poss early to mid 2004) is working on a programable cdi. I would think with both of these item's the V would be a totally different machine that it is stock.
I ordered both the HPD plain and EPI pink spring's yesterday to see which one I like best.
Per Don at Diamond G they are coming out with a performance cdi poss late next month
With both of these (unseen) mod's the V should fly and should feel like a whole new quad compaired to stock.
Also the Diamond G snorkel would be pretty much unseen unless some one was really looking for it but for optimum performance from the snorkel you will have to cut the indentation's out of the hood for a ram air effect but you could tell them it is for better cooling or something?
